221 user(s) are online (146 user(s) are browsing Forums)
Rimcrew Interchangeable Brake Parts - 2000 TA vs C5
40 Posts
I want to do the C5 brake conversion on my '94 and have access to a set of good calipers and abutment brackets from a 2000 TA. Does anyone know if they will work with the C5 adapters - the ones Jeff is going to be sending me any day now... ;-) I couldn't find a P/N anywhere on the brackets to do a search.
It sure would save me some $$ if this would work.
Thanks!
Posted on: 2008/7/23 3:16
Jeffvette Re: Interchangeable Brake Parts - 2000 TA vs C5
I thought you had already got some brackets.
Send me a PM :D
Oh, and the TA stuff is different. You can use the C5 caliper in the F-body bracket, but the bracket only pushes the caliper out far enough for a 12" rotor from my memory.
Posted on: 2008/7/23 5:20
