212 user(s) are online (173 user(s) are browsing Forums)
DaleD 2000 Grand Voyager leak
Cuyahoga Falls, Ohio
1389 Posts
My wife's Voyager has a coolant leak.
It's a 3.3L V6. The shop we take it to, told me it's a leak around the timing cover. That doesn't make sense to me. The timing cover has something to do with coolant flow?
Can anyone here confirm or correct that diagnosis?
Posted on: 2008/2/4 19:27
toptechx6 RE:2000 Grand Voyager leak
south Florida
362 Posts
The water pump mounts on the left side of the timing cover on the 3.3 or the front of the car when mounted transversely as in the Caravan. I can send you an illustration if you PM me a regular e-mail address.
Posted on: 2008/2/4 19:45
