109 user(s) are online (67 user(s) are browsing Forums)
corvetteronw Header bolt preferance?
Lowell, MI
What works for you. L98 applicaton, aluminum heads. In the past I have reused the stock bolts (80 Camaro and 81 Vette). I want ease of installation and to make sure I don't have to go back and redo them should they tend to lossen up.
Posted on: 2009/11/30 22:43
Durango_Boy Re: Header bolt preferance?
These look promising and you may never have to worry with them loosening or falling completely out.
http://www.jegs.com/p/Percys/Percys-S ... der-Bolts/981843/10002/-1
Posted on: 2009/11/30 23:32
corvetteronw Re: Header bolt preferance?
Lowell, MI
Thanks - I had not seen those before.
Posted on: 2009/12/1 0:02
biggrizzly Re: Header bolt preferance?
I have a set of Percy's in the packaging that I did not use. I'll sell them if you want them. $35 plus shipping. Paypal to go. Full set of 12, never been used.
Posted on: 2009/12/1 1:39
Lowell, MI
I will take them! PM sent
Posted on: 2009/12/1 1:57
1989GTA Re: Header bolt preferance?
61 Posts
I agree. The new Percy's are the way to go. I have a set made by another manufacturer from a few years ago and they have worked out great. Glad to see they are available again.
Posted on: 2009/12/1 4:33
