159 user(s) are online (92 user(s) are browsing Forums)
pappyfreebird pioneer head unit n speakers
1028 Posts
Pioneer TS-A6983R 6x9 4 ways
Pioneer DEH-2200UB head unit,,has usb etc 50x4 n 22 rms regular n easy bottuns fer this hack..awready have sum 6.5s new in box,,feel got great price 186 shipped fer unit speakers n free plug n dash mount..now lesse how there shippin n chit is,,orderd sun night n still sez proccesin..no hurry since locked in shed but still..well hope its a kick azz unit n is easy ta git er done..ain chure gonna use front speakers...thinkin on jus leavin wires unhooked n leavin front alone..i usually fade front ta 1/4 - 3/4 rear anyways...now i do like it cranked now n then so mebee ill hafta do fronts too ..see how bored i git i rekon...sonicelectronix is were bought online
Posted on: 2010/2/18 18:13
bogus Re: pioneer head unit n speakers
get new wire before installing all of that.
the old factory wire is junk by now.
Posted on: 2010/2/18 18:35
pappyfreebird Re: pioneer head unit n speakers
1028 Posts
yea bog i gots the wire...werent sure ifn gonna use it thou..been sittun here readin wud evo kin find on that topic..had came to mind that it would be ok fer this smallar powerd system ifn wire is good..then again have me a new wire snake might hafta try out
Posted on: 2010/2/18 19:15
Matatk Re: pioneer head unit n speakers
22806 Posts
You need to rewire the speakers. The factory stuff is not heavy enough. Not sure if you have bose, but if so you'll have to bypass the amps with new speakers.
The head unit will have enough power for the speakers you bought.
Posted on: 2010/2/18 22:59
1028 Posts
yea bro i gots bose in it stock 84..gonna pull all out (like you did) but were kinda hopin ta use same wires...do have it here thou if need it...
Posted on: 2010/2/19 1:10
1028 Posts
well will note ain to happy on the shippin chit fum this sonic electronix place..placed oreder 14th said in stock same er next day shippin,,but checkin there online chit it said addy prolem ..so hadda call seems they say cc dint have same addy,,i say been same 25 yrs git er done people..well then they shipped on 19 5 days later n say be here 25th..well hope the products lil betta then fast delivery..no hurry its winter ,,but they say same er next day etc..
Posted on: 2010/2/22 18:03
1028 Posts
arrived taday..same day shippin were a week er so slow but hey the boxes look noice n was well packed..spring spring come on spring come on boyz sing wid me bruthas fa lalalaalala!!!
ps gots me a new hair cut (avatar) you like,,hey speakin bout avatar i evo toll yous rednecks i avatar now too..yeup made new drive round me shed,,chure beats the fug outta gravel..plus now i kin say yea i avatar too bruthas,,,sum jus dont unnerstand when ask where my avatar is n i point out winder n say tis right there
Posted on: 2010/2/25 17:55
biggrizzly Re: pioneer head unit n speakers
I "avatar" too Pappy!! LOL
Posted on: 2010/2/25 19:01
1028 Posts
wahahhahahaa...
Posted on: 2010/2/25 19:23
1028 Posts
well 5 hrs n new tunes systems up n werkin....took rears out n jus used the base plastic n mounted the 4 ways n used stock grills...front was eavin easier,,i left stock chit jus removed bose speaker,then reached in n cut the 4 feed wires to amp n found the two that had noise n hooked me tails ta them..then used stock grill fer pattern i made 1/4 plywood same as grill,,then cut n mounted my 6.5s in wood usin new speaker grills ,so was like plug n play hooked me tails ta spearker n skeerood in grill holes..so good it were like i new wud i were doin...have a wood shop thou so wood is easy fer me..fer head unit i used the plug adapter n dash adapter..ony issue is my left right is reversed..did notice but chose fug it i ain switchin the plugs.. wires were all color coded so hadda be plugged one a tree in wrong... but she cranks noice looks good n best of all its done!!
Posted on: 2010/3/7 19:46
yay!
PS: Moving to audio.
Posted on: 2010/3/7 21:43
1028 Posts
pix suk but fer the budget minded heres my better then bloes system total invest 186. n few hrs swearin,,but sounds good n easily will accept a few more ponies ,,like a sony explode amp er such a pic of wud did wid door too very easy no takie door apart er nawtin..so wanna say thanks bruthas fer the advice n help..hope my lil bs here helps sum one too...
jpg  vet adapt 004.jpg (0.00 KB)
jpg  vet adapt 004 (4).jpg (0.00 KB)
Posted on: 2010/4/3 16:22
