pappyfreebird | well membar my babble on wheel adapters | ||
well orderd two sets n happy wid delivery etc..but werkin on kids trans am i decide throw a set his way..i did buy the hub n wheel concentric ones..dayum ifn the adapter to rotor is to tight n yeup it sez vet trans am comaro..anyways had mill the inner ta fit the outer ring.. werked fine n his studs did stick out a c-hair but stock rims had the holes so no grindin the ends,,all n all werked great..but werent a easy direct fit..will take a few pix when do vet n hope fits that wid out the etxree werk,,but drill press n mill bits will do the trick er die grinder etc,,kin cut n fit cut n fit er ya kin use a dial indacator n jus knock it out.. lathe er mill be evin shweeter..
Posted on: 2010/3/30 15:13
MK 82 | Re: well membar my babble on wheel adapters | ||
I would try to help you but I need a translation.
Posted on: 2010/3/30 22:01
96 CE Roadster LT4 |
pappyfreebird | Re: well membar my babble on wheel adapters | ||
dont need help on this one bro..got er done...but werent a simple bolt on..gonna do vet next...got er out yesterday..wooofugggaaannnhhoooya betta then viagra..
ceptin did notice a lil leak by left front wheel where she sat runnin a bit..oil..n thought how the fug ,,well i r gonna bet its powersteerin leak..hope nawt a ram...to many projects dint look hard,,but after thought is i think there was a hose clamp on one..fuggan a..hafta look closer soon...mk82 ain this the droptop brutha..chit ya used ta help me nawt gimme chit...be good brutha |
Posted on: 2010/4/1 12:56
I used to find it cute but now it is just very difficult to understand.
Posted on: 2010/4/1 16:02
fug bro i thought id been doin way better ..sarry fer the headaches...the mo excited i git the faster the babble n werse i gits ,,i kin type fast brutha (fer a two thumb headcase)),,but the werds dont aways look so good do they..no hey dont answer that we ll jus leave it alone k have a great one dude
Posted on: 2010/4/1 17:24
well fellas i tells ya wud ..tis really embrasskin ta walk round werk here wid this stiffieee!!! yeup yeup i drove her to werk today ,,snuck in a tad early to hose her down in my warsh bay...hose egine bay out real good sosin i kin see where that lil drip is commin fum...hopefully awready found it,,seems a loose clamp on power steer pump feed hose..hopin thats all she was.. they shouldnt be clamp any ways ain they under purty good pressure..well still was a blast commin ta werk taday,,n the new tunes sounded fine..dont ususlly jam at 5 am but taday i were headbangin bruthas...have a happy easter men
Posted on: 2010/4/2 12:01
ok well 1st they fit perfuclty,,piece a cake wipin em on,,(ceptin the muff center weldid cross brass right where my fuggan lil homeade piece used to fit fer the diff) anyways fit easy ..but dint like the look,,stuck out to far n coaul see the caster angle,,thats when realized n hoped well mebee she settle afta a drive..woot woot woot ..she did i,, i like um..heres couple fugged up pix..i prolly should go practice takin pix heyhuh...
Attach file: vet adapt 004 (1).jpg (0.00 KB) vet adapt 004 (3).jpg (0.00 KB) |
Posted on: 2010/4/3 16:26
