208 user(s) are online (158 user(s) are browsing Forums)
wilsonbh Painless Relay setup during Electric Water Pump install
17 Posts
Installing my Painless Relay, I chose to not install the circuit breaker it comes with since it has a 30amp fuse inline already. I saw the thing as a potential show stopper should it trip, another failure point in my electric water pump.
Has anyone else that used the painless relay for their electric water pump installation installed this device (circuit breaker) or left it out?
Billy
Posted on: 2008/1/9 9:58
1994 LT1 Coupe, Automatic, Hypertech Tuned/160 mod, K&N Filter
Meziere HD Electric WP, MSD Optispark, Copper Metallic
CasetheCorvetteman RE:Painless Relay setup during Electric Water Pump install
Id have installed it mate, it gives a buffer to the fuse. Would you rather replace the fuse or flick on a breaker?
Posted on: 2008/1/9 11:48
