117 user(s) are online (67 user(s) are browsing Forums)
kelley build date
thomasville ga
122 Posts
i probably missed it but how do you tell what the build day and month of your car? is it in the seral #? thanks
Posted on: 2008/1/16 14:39
RollaMo-LT4 RE:build date
Trivia Winner
Rolla, Missouri
422 Posts
You'll need the build sheet for your car. It's not part of the VIN (serial#).
There should be a sticker on the drivers door that will show the month it was built, but it won't show the actual day.
You can get a copy of the build sheet along with a replica of the window sticker from the Corvette Museum. :thumbleft:
https://store.corvettemuseum.com/services/buildsheet.asp
Posted on: 2008/1/17 0:57
CasetheCorvetteman RE:build date
The vin will tell you how many were built that year model before yours, cause its a sequence, my 94 is number 489
Posted on: 2008/1/17 7:16
kelley RE:build date
thomasville ga
122 Posts
great i found it ,,but now i`m confused,,,,,,, it is registered as a 94,,BUT date on sheet is 08 -93, did someone slip me one? or is it rite,,,
Posted on: 2008/1/17 16:08
Trivia Winner
Rolla, Missouri
422 Posts
Well they start building the next model year about half way through the previous calendar year.
So Yes, a 1994 Model year could very well have been built in Aug of 1993 or even sooner. I can't recall the exact cutoff date, but I think it could be as early as June or July. :thumbleft:
Posted on: 2008/1/17 16:36
