197 user(s) are online (119 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Grand Sport
RPO Z16.
A one year special. 1000 were made to honor both the end of the C4 and the original racers, called Grand Sports, from 1963.
All were...
Sherlock1506 C4 Bose Front Speakers Not Working
2 Posts
I have a 1991 ZR-1 and am experiencing problems with my Bose audio system. I've looked everywhere and have read about just about every problem possible with this audio equipment except the problem I'm experiencing.
My front speakers have no sound at all. Rear speakers work fine. Fronts don't crackle or pop. No sound.
I have heard reference to separate fuses for the front and back speakers. If this is true, where are these located?
Where else should I troubleshoot? I've already tried replacing the front amps with no success.
Thanks,
Jeff
Posted on: 2010/9/14 2:37
bogus Re: C4 Bose Front Speakers Not Working
I will have to dig out my manual and see what could cause this.
The receiver module could have died, too...
Posted on: 2010/9/14 2:46
I am betting on the receiver module.
There is only one relay that fires the amps, so I doubt thats it. If it was, you wouldn't have rear speakers, either!
The receiver module is located in the bin behind the drivers seat. Or it should be... they moved the damned thing around, too, it could be under the dash!!!
Posted on: 2010/9/14 23:06
Sherlock1506 Re: C4 Bose Front Speakers Not Working
2 Posts
Thanks... I appreciate the info. Any suggestion as to where I should send the receiver module for repair?
Posted on: 2010/9/15 19:44
Matatk Re: C4 Bose Front Speakers Not Working
#1, did you check wiring at the speaker amps to confirm you do or don't have power?
#2, Dr Don's is where everyone goes for head unit repair, not sure if he does the module repair.
ps - I know zero about the bose systems, so I'm not much help
Posted on: 2010/9/15 20:27
I agree with #1, but if there is no power, that means the circuit has been damaged... there is but one common power source for the bose.
#2 would be Dr Dons. I am pretty sure he does modules.
Posted on: 2010/9/15 23:00
