312 user(s) are online (273 user(s) are browsing Forums)
brut NEW Points system **UPDATED**
New Albany, IN
1308 Posts
Just for fun and to show is more active on the site I added a trial points system. The reults are on the left side of the screen.
Here is how the points are handed out:
Start a NEW post: 20 points
REPLY to a post: 10 points
Vote in a Survey: 5 points
Comment in a Survey: 5 points
Each page viewed: 1 point
UPDATE:
Each time a member reaches 10,000 points, they will receive one of the following:
1) C4guru Coffee mug
2) C4guru License Plate
3) C4guru T-Shirt(if available)
More prizes will be introduced in the future.
This contest can be canceled or changed at any time without notice. In other words, if I am paying out a lot of money for prizes, I may be losing my azz, so I may change the rules or cancel it. I will limit each member to 2 prizes. So after 20,000 points there will be no more prizes.
Have fun!
Posted on: 2006/8/23 1:57
freakd RE:NEW Points system **UPDATED**
727 Posts
what will the points be used for???
Posted on: 2006/8/23 9:44
brut RE:NEW Points system **UPDATED**
New Albany, IN
1308 Posts
I dunno...maybe a free T-Shirt at a certain point? Any ideas?
Posted on: 2006/8/23 9:45
Alcee1 RE:NEW Points system **UPDATED**
Los Angeles
277 Posts
Cool, I want a T-Shirt
Posted on: 2006/8/23 22:04
New Albany, IN
1308 Posts
Yeah..maybe 10,000 points gets a shirt or something. You will have to work for it, thats for sure!
Posted on: 2006/8/23 22:19
New Albany, IN
1308 Posts
Updated..see original post
Posted on: 2006/8/23 23:07
727 Posts
dayum, i better get busy, juggling 3 forums and poker is no fun
Posted on: 2006/8/24 0:07
90EXPVette RE:NEW Points system **UPDATED**
Martinez, Georgia
185 Posts
That's a pretty neat system! Should really liven up the board!
Posted on: 2006/9/6 17:47
727 Posts
:thumbright: :thumbright: :thumbright:
Posted on: 2006/9/6 18:04
Martinez, Georgia
185 Posts
Is the points system retroactive? Did you start counting the points at a certain point or will all of our posts be counted
Posted on: 2006/9/20 11:57
New Albany, IN
1308 Posts
I started the points system in Late August of this year so anything done before that will not have points awarded. Sorry......I don't think there is a way to go back and do it. So get busy!!!!
Posted on: 2006/9/20 20:58
VR-92 RE:NEW Points system **UPDATED**
68 Posts
Looks like Freakd is getting close to a coffee mug.
:thumbleft:
Posted on: 2007/7/23 18:53
