-=Jeff=- | AH, Active here I come | ||
I just bought a Coustic XM6. It has a bandpass crossover and will be perfect for setting up my system
I sold my Eclipse 5083 and the Nak has no Crossover.. this XM6 has a High, Bandpass and Low.. even has the Remote bass knob.. |
Posted on: 2011/6/24 2:20
bogus | Re: AH, Active here I come | ||
One day I will show up on your door step... just warn'n ya.
Posted on: 2011/6/24 3:11
-=Jeff=- | Re: AH, Active here I come | ||
LOL, Why you looking for a xm6? do you want a XM3? I have one it is missing the power harness, but I have the parts to make one Actually I was cruising ebay and found something even BETTER.. Eclipse: CD Tuner ECD-510 Sound Processor EQS-2000 DSP Controller EQR-2140 With all wiring... This was my dream system when I bought my ECD-413 years ago |
Posted on: 2011/6/24 3:15
which would be better for me? full active or Semi Active? Full active is better but due to my equipment and power I am not sure..
here is what I have Nakamichi CD400 two Arc KS 300.4 Front Stage: 1" Tweeter 4" Mid, 6.5 Midbass Rear: 6.5 woofer (might swap to an 8") Current setup has one amp bridged to the rear and one amp bridged to the front with a 3-way Passive I just bought a XM6 which will give me the last iece to go active in one of 2 ways: Active Option 1: Amp 1 2 channels to a passive for the 1" and 4" (I have a set of 2 way passives) 2 channels for the 6.5 midbass Amp 2 Bridged for the Woofers Active Option 2: Amp 1 2 channels for 1" tweeters 2 channels for 4" midrange Amp 2 2 channels for 6.5 midbass 2 channels for Woofers Active Option 1 uses the XM6 for crossover duty Active Option 2 uses the XM6 as well as the croosovers on the Arc for the midrange and midbass as well as the XM bandpass. AMP Specs: Power output RMS @ 4 ohms 4 x 90 watts Power output RMS @ 2 ohms 4 x 175 watts Power output RMS @ 4 ohms bridged 2 x 350 watts Thoughts and/or opinions? |
Posted on: 2011/6/25 2:47
