222 user(s) are online (191 user(s) are browsing Forums)
-=Jeff=- AH, Active here I come
Bartlett, IL
573 Posts
I just bought a Coustic XM6. It has a bandpass crossover and will be perfect for setting up my system
I sold my Eclipse 5083 and the Nak has no Crossover.. this XM6 has a High, Bandpass and Low.. even has the Remote bass knob..
Posted on: 2011/6/24 2:20
-=Jeff=-
1990 Corvette ZR-1 #1051
bogus Re: AH, Active here I come
One day I will show up on your door step... just warn'n ya.
Posted on: 2011/6/24 3:11
-=Jeff=- Re: AH, Active here I come
Bartlett, IL
573 Posts
LOL, Why you looking for a xm6?
do you want a XM3? I have one it is missing the power harness, but I have the parts to make one
Actually I was cruising ebay and found something even BETTER..
Eclipse:
CD Tuner
ECD-510
Sound Processor
EQS-2000
DSP Controller
EQR-2140
With all wiring... This was my dream system when I bought my ECD-413 years ago
Posted on: 2011/6/24 3:15
-=Jeff=-
Bartlett, IL
573 Posts
which would be better for me? full active or Semi Active? Full active is better but due to my equipment and power I am not sure..
here is what I have
Nakamichi CD400
two Arc KS 300.4
Front Stage:
1" Tweeter 4" Mid, 6.5 Midbass
Rear:
6.5 woofer (might swap to an 8")
Current setup has one amp bridged to the rear and one amp bridged to the front with a 3-way Passive
I just bought a XM6 which will give me the last iece to go active in one of 2 ways:
Active Option 1:
Amp 1
2 channels to a passive for the 1" and 4" (I have a set of 2 way passives)
2 channels for the 6.5 midbass
Amp 2
Bridged for the Woofers
Active Option 2:
Amp 1
2 channels for 1" tweeters
2 channels for 4" midrange
Amp 2
2 channels for 6.5 midbass
2 channels for Woofers
Active Option 1 uses the XM6 for crossover duty
Active Option 2 uses the XM6 as well as the croosovers on the Arc for the midrange and midbass as well as the XM bandpass.
AMP Specs:
Power output RMS @ 4 ohms 4 x 90 watts
Power output RMS @ 2 ohms 4 x 175 watts
Power output RMS @ 4 ohms bridged 2 x 350 watts
Thoughts and/or opinions?
Posted on: 2011/6/25 2:47
-=Jeff=-
