Micke3 | Problem with housing C4 -88 | ||
Hi!
I have a problem with the housing in my c4 -88 When i turn on the ignition the lighting in the housing doesn't work and the lamps to the indicators are lit all the time. but not on the outside of the car. all the meters works fine but its hard to see them without any light in the housing. |
Posted on: 2011/6/30 10:54
bogus | Re: Problem with housing C4 -88 | ||
Are you talking about the dash board?
Posted on: 2011/6/30 17:32
Fredbird | Re: Problem with housing C4 -88 | ||
You are talking about the digital cluster (Speedometer etc.)
The digital readout is all dark, but if you look really close or in bright light you see it working. But there is no backlight. Also, both of the direction lights as well as the High beam light indicators are on. You have a broken ground in your cluster. This happened to my dad's 86 corvette... Real pain in the butt to fix. This link explains it all.. http://batee.com/corvette/dcrg/index.htm You want the article with the following title: The Digital Cluster Turn Signals and High Beam Lights are Always Lit If you need the schematics for the different ground pins etc... they are also on that site. |
Posted on: 2011/6/30 19:01
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. |
Ultraman | Re: Problem with housing C4 -88 | ||
Welcome to the Guru!
Posted on: 2011/6/30 20:48
Micke3 | Re: Problem with housing C4 -88 | ||
excuse my bad english :/ "fredbird" is right, thanks for the help
and thank you "ultraman" |
Posted on: 2011/7/4 12:07
No problem... Glad to help.
Posted on: 2011/7/4 12:25
Where are you from, Micke?
And welcome aboard! |
Posted on: 2011/7/4 17:05
istter1 | Re: Problem with housing C4 -88 | ||
Had to replace mine here is a guy that will send you a repaired unit guarenteed I think it was for a year. Mine works great. There is a core charge but he will send it to you and refund the $100 core charge when you send yours .
Posted on: 2011/7/8 1:16
scan didn't show. Scarabexc@aol.com I bought a Corvette C4 digital dash instrument cluster Oct 10 2010 Price was $275 $110 Shiping and handling $385 total. He will ship it to you for the Price I paid and then you send yours to him and he gives you your deposit back. Took about a week to receive easy to install. Works great and has a warrenty.
Posted on: 2011/7/8 1:24
