155 user(s) are online (126 user(s) are browsing Forums)
istter1 Catalytic converter high cost in California and poor palcement design
Bakersfield Ca
2336 Posts
Why would someone place the heat of a Catalytic converter so close to oil filter, clutch slave cylinder and other heat sentive parts. I thought the heat sheilding for the 80's floor board were a symble of the factory poor design.
In california one converter will cost 3-5 hundred dollars un installed because of an enviromental tax. This started this year.
Is there a way to keep heat away from all the heat sentive parts?
Posted on: 2011/7/10 1:10
bogus Re: Catalytic converter high cost in California and poor palcement design
First off, mail order a cat via summit racing.
You can use heat wrap materials from summit racing, also.
You have a 1985, right?
Posted on: 2011/7/10 1:15
istter1 Re: Catalytic converter high cost in California and poor palcement design
Bakersfield Ca
2336 Posts
"87" not in need of one yet. When I need one my daughter will ship me one from New Mexico. knock 0n wood
Posted on: 2011/7/10 2:34
Carol Burnett
yea... it's an easy DIY project.
The cats on my 92 are up next to the oil filter and fuel filters... but they are shielded and are in the air flow. I can't say they have hurt anything... But you gotta keep the clutch hose retained to the firewall!!!
Posted on: 2011/7/10 2:38
Bakersfield Ca
2336 Posts
We were going to wrap them in insulation also
Posted on: 2011/7/10 5:01
Carol Burnett
Do this, gut the pre-cats... they are beyond pointless.
then, put a piece of heat mat material - the reflective stuff - along inside the trans tunnel.
You cannot wrap cats, it will over heat and kill them.
Posted on: 2011/7/12 4:18
Bakersfield Ca
2336 Posts
good idea as they are only visually inspected.
Posted on: 2011/7/12 17:00
Carol Burnett
