Fredbird | high pressure a/c line | ||
Looks like the schrader valve on the high side of my system is leaking. I am wanting to convert to R134a but this requres me to remove the valve stem but it seems the stem is not removable. Anyone else done this or run into the same problem? Is the valve really not removable or do you need a tool other than a normal stem tool?
Posted on: 2011/9/9 0:00
Life moves pretty fast. If you don't stop and look around once in a while, you could miss it. |
joeld | Re: high pressure a/c line | ||
Yes, the valve can be removed. IIRC it just sits deeper in than a regular type (tire) valve. I'm thinking NAPA has the tool, not certain. I know the AC supply sites have them.
Here is one site for new valve: http://centuryautoair.com/mcart/index.cgi?code=3&page=0&cat=9 Joel |
Posted on: 2011/9/9 1:06
1989 Coupe,L98 automatic |
Here ya go
http://shop.advanceautoparts.com/weba ... -P_N3569_T%7CGRP2001_____ They also have the valve core. joel |
Posted on: 2011/9/9 1:54
