128 user(s) are online (100 user(s) are browsing Forums)
matts85vet $1F parameters-what do they mean?
Toledo, Ohio
58 Posts
just got an autoprom and g2 adapter installed for the '85 and started playing with the parameters.
what do they mean? anyone know of a good explanation for all the parameters?
some are obvious-fan on temp, etc.
what does delta mean?
looking for a glossary of the parameters and what each one means and what happens when you increase or decrease the value.
thanks in advance!
Posted on: 2011/9/16 14:00
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
mistaben Re: $1F parameters-what do they mean?
141 Posts
... there is usually a hacked file that explains all the different parts to your prom.
try thirdgen.org, they have alot of information over there.
delta = change of/change in.
ex:
delta TPS = change in the Throttle Position.
it's not the throttle position that that relates to but, it's the amount of the change in the throttle position.
I use tunerproRT v5 for some of my explanations...
and then other's I go look up online, usually end up scrolling through the archive files at thirdgen.
Posted on: 2011/9/19 4:06
