298 user(s) are online (224 user(s) are browsing Forums)
GRIS, more...
« 1 (2)
SpectatorRacing Re: 90 ..just does not have it...?
I have the solution to your problem, a sweet 383 LT1 ready to drop right in
If this isn't resolved by next week I can try to lend a hand, I'm in China right now so "local" is not the case. I will admit, however, that I'm no expert on the extraneous systems such as HVAC and cruise control as I "fix"them by removing them.
Are you sure all cylinders are firing? Down on power and a vibration at speed sounds to me like a misfiring cylinder...
Posted on: 2012/1/30 5:49
1990Rudy Re: 90 ..just does not have it...?
37 Posts
the cruise does work...
Posted on: 2012/1/30 14:53
37 Posts
No misfire
Posted on: 2012/1/30 23:26
37 Posts
UPDATE, YES the Cruise and the blower only come out the Defrost vents and not the vents that would blow directly toward you.
Posted on: 2012/3/9 22:17
bogus Re: 90 ..just does not have it...?
that's something vacuum related. The dashpots are vacuum powered, so if there is a problem it could be in the programmer.
Posted on: 2012/3/9 22:22
« 1 (2)
