207 user(s) are online (63 user(s) are browsing Forums)
j3studio [Weird Question #??] How Long Are Power Antenna Leads?
[1985 original power antenna]
The leads were snipped at some point a while ago - how long should they be?
Posted on: 2012/2/18 17:27
BillH Re: [Weird Question #??] How Long Are Power Antenna Leads?
Long enough so you can plug them in.
The leads for the motor or the antenna cable?
If you have no more NCRS worries, the leads for the motor won't matter length wise.
Posted on: 2012/2/18 17:37
bogus Re: [Weird Question #??] How Long Are Power Antenna Leads?
20878 Posts
on the antenna, they are just long enough to reach the rear bulkhead, maybe 18"?
Posted on: 2012/2/18 19:13
j3studio Re: [Weird Question #??] How Long Are Power Antenna Leads?
Thanks, guys!
Posted on: 2012/2/18 21:18
Woodstock Re: [Weird Question #??] How Long Are Power Antenna Leads?
Bremen/Germany
369 Posts
I've got an old 88 antenna and a spare 91, which looks different. The 88 may be like yours? It measures 60 inches from the tip of the plug up to the antenna motor.
The inside part is 27", which leaves 33" for the outside.
It came from a coupe btw.
If you like pictures to compare, let me know.
Posted on: 2012/2/18 22:20
91 convertible
