296 user(s) are online (252 user(s) are browsing Forums)
« 1 (2)
Matatk Re: Trans problems.....signs of a bad torque converter?
1st Gear 3.06
2nd Gear 1.63
3rd Gear 1
4th Gear 0.70
Posted on: 2012/3/25 2:18
dan0617 Re: Trans problems.....signs of a bad torque converter?
High stalls work nice when you whack them with alot of power though.....I have my combo back together and the wot stall is crazy. At 6300 rpms when it shifts 2-3, it only drops to about 5700 rpms. Sure keeps the boost up! I'm seeing 15 lbs of boost and with a big shot of 75% meth, 25% water. One run like that and it makes all the high rpms at part throttle worth it.
Posted on: 2012/3/27 2:23
I'm telling you, Dan. When the trans is warm and I jump on it through the upper RPMs, it's like a beast.
Posted on: 2012/3/27 2:27
That is good. You must be making good power.
Only bandaid I've found to help is that TCI constant pressure valvebody, so I can set the TV cable wherever I want to raise the part throttle rpm shifts. I too played alot with the governor weights and springs to no avail with any of the part throttle stuff.
Posted on: 2012/3/27 2:38
I know of the TCI constant pressure body, but I've heard bad things about keeping constant pressure on the trans. Dana at Probuilt doesn't recommend it.
Posted on: 2012/3/27 11:34
« 1 (2)
