294 user(s) are online (249 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
BeachBum 85 Corvette injector ecm
751 Posts
As per my schematic, what I know about the Injectors on an 85 ECM.... is that both cylinder banks are powered at the same time, but are fused seperately. Then the injectors are activated by grounding each bank seperately via solid state ecm activation. Each bank has its own driver output from the ecm for this.
What I do not know.... do the drivers activate each bank at the exact same time or does each bank fire at different times. I think just because there is a seperate driver for each bank, doesn't mean they fire at a different time, hence this is what I am trying to find out.
Does anybody know "definitively" how the 85 ecm works ?
Thanks.
Posted on: 2012/5/18 18:53
