693 user(s) are online (349 user(s) are browsing Forums)
Transverse Leaf Spring
chisgt Edelbrock 1812 Thunder Series AVS Carburetor CFM: 800
chitown
58 Posts
Thunder Series AVS, Carb, New, 800cfm,Sq-Flange,Man. Choke,w/o EGR,Pri. Jet-.113/Sec. Jet-.101,Metering Rd,Dual/Sml Sngl Plane Intke,Street/Hi Perf. Usage
Distinctive Black Accented Hardware
GM/AMC-Style Throttle Linkage
Metering Rod/Step Up Springs Can Be Changed Easily
New Qwik-Tune Adjustable Secondary Air Valve
No Gaskets Below Fuel Level to Prevent Leakage
Optional Single Or Dual Fuel Inlet
CFM: 800
Manuel Choke
Call Tim at 773-551-6914 $175.00obo I had this on a heavily cammed big block and it ran well. I have since gone to fuel injection. This carb has approximately 3000 miles on it and ran fine. Plus shipping if not picking up
Posted on: 2012/5/30 2:18
