160 user(s) are online (119 user(s) are browsing Forums)
bam stock timing and VE tables
missouri
250 Posts
Could someone post the stock timing and VE tables for the 93 Vett? I have somehow lost mine in all the tuning I have been trying to do on my 93, sure would appreciate it.
Posted on: 2012/11/16 15:21
bogus Re: stock timing and VE tables
isn't that data available via TunerCat? I should have it if that's the case...
Posted on: 2012/11/16 18:49
bam Re: stock timing and VE tables
missouri
250 Posts
Bogus, yes you can read your stock tables with TunerCat. If you have the ECM file on your laptop/desktop computer already you can just load it in TunerCat and then do a screen print of the appropriate tables. If not on your computer then you will have to have the Moats flash and burn program and a chip burner/reader to read the chip. Thanks
Posted on: 2012/11/16 19:48
missouri
250 Posts
You could also just sent the whole stock ECM bin file, whatever works best for you. I finally have my idle and part throttle VE's working pretty good, but now I am very rich at WOT, around 10.0 AFR reading on my wide band 02.
Posted on: 2012/11/17 0:34
Woodstock Re: stock timing and VE tables
Bremen/Germany
369 Posts
click here for auto
or here for 6 speed
Those bins are all out there and not that hard to find.
Posted on: 2012/11/17 1:15
91 convertible
