215 user(s) are online (144 user(s) are browsing Forums)
TimAT Safety thing-- LOOK!!
Gladstone, MO (Kansas City)
38 Posts
There are a lot of guys that do their own repairs- Electrical, Mechanical, the whole show. If you do them anything like I do, you want he repairs to be neat and permanent. If your car has HEI ignition you need to know this one. If you're repairing any wiring and use a Weller type soldering gun, the magnetic field the gun has around it when it's on WILL repeat WILL cause your HEI to fire if the ignition is on. I shot this video as a demo. The HEI is simply stuck in a bench vise, and has 12 volts from a battery charger hooked to it. That's all. Imagine yourself leaning over the fender, key is on, fixing a broken wire. You reach over, grab that trusty old soldering gun, pull the trigger and]Resized Image[/URL]
If the rotor is lined up with a cylinder that's ready to fire (and it usually is) it can and has caused the engine to start.
Posted on: 2008/2/25 7:06
CasetheCorvetteman RE:Safety thing-- LOOK!!
Champion mate, thanks very much for that!!
Posted on: 2008/2/25 7:37
Matatk RE:Safety thing-- LOOK!!
That's crazy - good tip.
Posted on: 2008/2/25 23:23
