BV85 | WHEELS | ||
Is anybody here useing the cadillac skiney wheels. If so where did you get them. How much time did you cut on ets.
Posted on: 2013/5/25 5:55
bogus | Re: WHEELS | ||
I am not sure if they would even fit right. I have no idea about their specs.
If you want skinnies, Weld makes'm and they do fit right. |
Posted on: 2013/5/25 15:03
93ragtop | Re: WHEELS | ||
Don't know about those, but I can tell you I have for street wheels, GS replica's 17x11 and 17x9.5 with 315 and 275 tires. For drag racing, I have weld lites, 15x10 with 275x50x15 tires and 15x3.5 with 165sr 15 tires. The weight difference is 75lbs total. This makes 1 to 2 tenths difference with IMO closer to 2 tenths.
Posted on: 2013/5/26 21:20
93 White Vert. 3.73 gears, Yank 3000 converter,385ci. Built by Rklessdriver!! Ross pistons, Scat Rods, and Crank, custom Mike Jones Cam, AFR 210 heads, Exotic Muscle LT headers, magnaflow mufflers Meziere water pump. My best run 11.19 ET at 124.63mph |
