162 user(s) are online (124 user(s) are browsing Forums)
Also known as the DIC.
ironcurtain Help with Valve Covers
39 Posts
Hey guys,
I have been having issues with this and need some help. I have LT4 Roller Rockers and i have my LT1 stock valve covers on there but i think there might be some clearance issues( i have double gaskets, i know not smart but i did it at the time) I had some valve covers i could put on unfortunately it wont' fit on the driver side because of the alternator clearance. Do you guys know anywhere where they sell valve covers for the LT1 that are higher than stock but will fit the driver side without hitting the alternator? thanks
Posted on: 2008/2/25 18:34
1995 Aqua Metallic Corvette. LT4 Hot Cam, Ported Heads, 3.73 Gears, Edge Torque Converter, Long Tube Headers, and X-Pipe.
dan0617 RE:Help with Valve Covers
I don't know anything about LT1 but on L98 the stock valve covers will clear narrow body 1.6 rockers as long as you remove the drip tabs. There is no problem with double gaskets as long as you have them positioned perfectly when you tighten the valve covers down so they don't leak. Why do you think you have clearance issues? Are the rockers hitting the valve covers on the inside?
Posted on: 2008/2/25 23:49
ironcurtain RE:Help with Valve Covers
39 Posts
i really don't think they are hitting but after switching the passenger side valve covers with taller valve covers the car feels like it breathes better especially at higher RPMs but well see. Thanks for the Reply.
Posted on: 2008/2/26 5:02
JAKE266 RE:Help with Valve Covers
Kempner, Texas
22 Posts
I had a similar problem when I built my 388. The stock covers wouldn't drop all the way down to the head due to poly-lock clearance. Locks were too tall.
I tried shorter poly locks and even clearancing the inside of the cover but still not enough clearance.
So I went with ProForm 1/4" taller covers from Summit; black krinkle with red CHEVROLT logo. The passenger side dropped down all the way and buttoned up fine, but not the driver's side; the alternator became the obstable.
So I used a Sharpie and marked the area on the alternator where the cover hit, removed the alternator and, using a grinder, ground off the offending area. That's all it took.
I first masked off all the openings in the alternator so no aluminum chips would get inside.
Jake
Posted on: 2008/2/26 18:44
__________________
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
