istter1 | 87 vett loses 3 cats at same time | ||
Well lost 3 cats at same time.
One theory rear cat clogged first making precats fry. Next. Vet slow start first time in morning. Excess fule in cats caused them to.melt down. Next they were old and all failed at same time. Tomorrow. Compression test Fule pressure test Injector test Make sure the 50000volt coil is working correctly. Already cleaned out mufflers. Exaust sounds great now. Anyother suggestions. |
Posted on: 2013/9/17 0:44
josephf31 | Re: 87 vett loses 3 cats at same time | ||
Main cat on my '91 was completely (and I mean completely, nothing but a metal shell) blown out. Still failing emissions I think the precats are likely shot too. How did you determine all 3 cats bad, did you pull and inspect them all? As for the slow start, I'd begin with checking the fuel pump that caused a of problems on my L98. |
Posted on: 2013/9/17 0:54
2002 Magnetic Red C5 6 spd LS1 convertible |
Matatk | Re: 87 vett loses 3 cats at same time | ||
I would check your tune and figure out why so much excess fuel. Cats can go back after a long period, make sure everything is in good order and didn't contribute to it.
Posted on: 2013/9/17 1:36
bogus | Re: 87 vett loses 3 cats at same time | ||
yea, sounds like a tuning issue... too fat or too lean will kill a cat..
Posted on: 2013/9/17 2:05
istter1 | Re: 87 vett loses 3 cats at same time | ||
We took them apart. All shot. Mufflers full of crap. They shut the engine off.. Heated up everything. I have always thought I had a problem because I was losing so.many slave cylinders. Thst is why I went with the Mcloud hydrolic throw out bearing. The fule pump.is 6 months old. But recently the fullle gsge d 5 gallons off. Easy to pullout and check |
Posted on: 2013/9/17 2:10
Edited by istter1 on 2013/9/17 2:34:41 |
These cats have been dying for a while then.
But I would still like to see some O2 sensor numbers before knowing if it was fat or lean. |
Posted on: 2013/9/17 2:37
When I.get out of dr. Apoinment we have all the test equipment and smog equipment Finally have a little time at the shop Lol |
Posted on: 2013/9/17 3:11
You know Andy you jared my memory of the problem of getting the Vet, with the new engine, to idle. My buddy John stepped up the TPS so it would idle smothly. I will check that out tomorrow. Thanks for the brain storming session!! http://www.oreillyauto.com/site/c/printablelist.oap |
Posted on: 2013/9/17 4:10
Edited by istter1 on 2013/9/17 4:26:16 |
TPS and IAC won't effect mixture.
Posted on: 2013/9/17 15:51
Replacing it any way.
11:00 am when I get out ofdr we will find out what the cause was I hope |
Posted on: 2013/9/17 16:14
dude... don't throw money at it... diagnose and fix the right way...
If they are newer, they are fine. I am betting that whomever tuned it has it running a bit rich, and if anything, a weak or dead O2 sensor wasn't up to the job. I am also sure that 02 sensor is about gone. Do you have a friendly smog guy? If so, I would suggest you get an LT1 style cat back with a pair of Mangaflow cats... they will work on the 383 just fine, and will work better than the three that were there... one on each bank, and will flow better than anything else on earth, really! See if you can track down an LT1 dual exhaust. There is a used part vendor - I will find him - down here in the Ontario area. A used OEM LT1 cat back is CHEAP... get the good cats, hangers and such, and you have just liberated another 30hp from that engine. Seriously. And it will pass sniff any day of the week. I just wish the L98 engine controller could read 2 O2 sensors... |
Posted on: 2013/9/17 19:29
sounds cool Let me know
Still working on a better tune right now. |
Posted on: 2013/9/18 16:28
Andy is this simular to what you were talking about?
http://www.corvetteguruforum.com/modu ... ewtopic.php?topic_id=4207 |
Posted on: 2013/9/18 16:34
I seem to recall that the lt1 cats are not a direct swap to the L 98. The later cars had a clearance area in the frame rail where the lt1 cat sits. I know there is a thread out there outlining the differences.
Posted on: 2013/9/18 21:51
http://forums.corvetteforum.com/c4-te ... 1-exhaust-on-l98-car.html
What Joe said when he tried the swap: Quote: The offset oil adapter does not have provision for the cooler. |
Posted on: 2013/9/19 0:47
Wow lot to do.
Posted on: 2013/9/19 2:35
While checking lines we foung the vacume line going to the fuel pressure regulatered almost melted close.Fuel pressure varried from 40 -50 lb. Installed tpi and would have to reve engine to keep engine running. throwing code for mass flow sensor. Sensor ok. Might not be grounding correctly because prior fire damage to wires. Will pull computer and ground. Computer from autozone a year old. Problem of pre codes could be computer will check that out Life time warrenty Autozone. Any suggestions on Idle and mass air flow sensor. |
Posted on: 2013/9/19 5:25
if you think the wire are damaged, chase them.
digital multi-meters are your friend here. make sure the wires are not damaged in some way. The magnaflow cats are much smaller than the LT1 cats, so you don't need to worry so much about the frame in the way. |
Posted on: 2013/9/19 14:01
When I get off work today will be third time this year for simular problems. Wish we never had the fire lol |
Posted on: 2013/9/19 18:03
fires suck....
I wish I was closer... but I will be around if you have qx, just post away! |
Posted on: 2013/9/19 23:44
Chased wires not a problrm.
Had to drive to Lamont to get another ecm Autozone good warrent |
Posted on: 2013/9/20 1:18
that warranty has now been used up.
I hope that's the problem!!! |
Posted on: 2013/9/20 3:04
Will know later today..
I think there may be more to the tune. |
Posted on: 2013/9/20 13:19
Not to be an ass, but "duh" comes to mind.
cat's die for 2 reasons - too much fuel or not enough. |
Posted on: 2013/9/20 16:37
you know the nice thing about this site is after a while people treat you like family. Say something STUPID and lol Thanks for the help Andy lol |
Posted on: 2013/9/20 20:10
just being me.
![]() as I said above, I would really love to know what the O2 sensor is saying. you may even need a wide band to do the tune with... But that's the problem with tuning these older engines... is so manual... burn the chip try again burn again... |
Posted on: 2013/9/20 21:05
It's alive
The money pit lives on |
Posted on: 2013/9/21 0:20
yay!!
cause?? |
Posted on: 2013/9/21 0:22
After replacing computer the tune took.
Put it on smog machine will pass without a problem. No throttel hesitation Took a fine adjustment on tps so the maf sensor to work correctly Cleaned throttey body All I know is everything is working correctly Duh Lol |
Posted on: 2013/9/21 2:25
I am so glad!
I wonder if the chips were properly installed in the old computer? just thinking... |
Posted on: 2013/9/21 14:08
If the piggyback chip wasn't installed correctly it probably would run in limp mode or if the adapter wasn't installed correctly it probably wouldn't run at all.
With the new computer in and everything running I would datalog it immediately and check the 02 function and fuel learn tables. |
Posted on: 2013/9/21 16:41
With the new computer in and everything running I would datalog it immediately and check the 02 function and fuel learn tables. We have all the information at the shop Good advice Since the day I bought this 87 Vet it has been so hot in the cabim. If you put a foam cup in the holder it would mealt a little the shifter metal was hot as hell. Themputer under the hood by either bank was scorching. Not now. I am wondering if the heat destroyed all the slave cylinders. They all showed signs of heat. Fluid boiled off readily. No problem since we installed the Hydrolic throw out bearing With the new cats you hardly notice it Thanks Guys for the help Steve |
Posted on: 2013/9/22 0:49
Your cats were surely overheating for all this time and causing the heat issue in the floorboards. I'm glad they didn't damage anything else. I know we theorized heat could be causing the problems in the past with the clutch hydraulics but never figured it was from the cats being/going bad. Wow. Good info for the future and hopefully that solves a lot more problems!
Posted on: 2013/9/22 13:00
