johnven | Need Help 86 4+3 OD not working | ||
OD light is on and will go into overdrive when coasting on highway or street, as soon as gas is applied slips into lower gear. Just filled off fluid with dealer ( it was low) car has 29000 miles and this just started last time out the other day. Was hoping fluid would do it but no luck, any idea's can it be the relay? Anyone have a similiar problem? Help please if you can thanks.
Posted on: 2005/9/21 22:05
bogus | RE:Need Help 86 4+3 OD not working | ||
Gee... I would get a copy of the factory service manual, and follow their debugging instructions. www.helminc.com
you can also find copies on eBay. |
Posted on: 2005/9/30 14:33
Arisa | RE:Need Help 86 4+3 OD not working | ||
The 4+3 is basicly a 4 speed with a powerglide auto behind it. As Bogus said I'd grab a factory manual to start with. I can't remember if that unit uses vacuum to operate the OD or it's completely electrical.
Posted on: 2006/2/18 0:52
fully electronic. I would be sure that the connections have not been messed up too much by grease and grime...
Posted on: 2006/2/18 6:19
