313 user(s) are online (285 user(s) are browsing Forums)
Steve40th Checking transmission fluid level when cold, 700R4/4L60
1114 Posts
Where can the mark be. Mine is right at the grid where it is supposed to be when hot.. Its a little above cold. The engine oil temp was 140 degrees. Had some little droplets on bottom of pan. Pan is new with recommended high end gasket, dont remember the name but it was around 12 bucks, LOL.
[URL=http://s280.photobucket.com/user/rivary0006/media/20130929_084227.jpg.html]Resized Image[/URL]
Posted on: 2013/9/29 16:08
Ko'u ohana aia ku'a ikaika
Matatk Re: Checking transmission fluid level when cold, 700R4/4L60
22803 Posts
Was it running?
Posted on: 2013/9/29 17:42
Steve40th Re: Checking transmission fluid level when cold, 700R4/4L60
1114 Posts
yes, 140 engine oil temp. 850 idle, not stock 396LT1.
Posted on: 2013/9/30 0:28
22803 Posts
I'd run it hot and check it at idle on a level surface. I think you're fine, but if you think you are over suck a little out.
Posted on: 2013/9/30 0:33
bogus Re: Checking transmission fluid level when cold, 700R4/4L60
that fluid expands as it gets hot, IIRC... so get it up to op temp.
How you been???
Posted on: 2013/9/30 1:40
1114 Posts
How you been???
Hey, Been living the life as a contractor, LOL.
I will run it hot and see what happens. I think because it sat for so long it just leaked.
Posted on: 2013/9/30 9:36
22803 Posts
It shouldn't really leak from sitting a short period. I guess if it sits really long and seals are dried out/bad it will leak. The pan gasket shouldn't leak. You might have fluid coming from the dipstick tube grommet, vss, etc.
Posted on: 2013/9/30 16:15
1114 Posts
I took the best pics I could of above the pan. I cant see any fluid coming out of dipstick tube. I saw some on the shifter linkage. None on the servo. I cant physically see the TV cable area. But, I will next time I get under.
Posted on: 2013/9/30 20:52
