207 user(s) are online (147 user(s) are browsing Forums)
A Collector Edition, RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
DMGroh Body Codes; ABS Codes
1 Posts
Probably the most definitive list of OBD-II "P" (Powertrain) codes I've found on the net is at
http://www.3800pro.com/lists/obd2codes.html
My questions is: Where can I find a comprehensive list of GM Body Codes, ABS codes, Airbag codes, etc. ..?
I can pull the codes, I just need to look them up without the (benefit and expense of the ) GM Tech 2 scan tool.
Posted on: 2006/10/4 14:59
CasetheCorvetteman RE:Body Codes; ABS Codes
Factory service manual mate
Posted on: 2006/10/4 15:23
red_johnny RE:Body Codes; ABS Codes
Posted on: 2006/10/4 17:02
DMG RE:Body Codes; ABS Codes
2 Posts
I have the FSM; actually several for the different GM cars that I have. The codes I seek are not in ANY of the FSM's.
If I'm wrong, show me which page the following are: E504, E545, E585, 4100, 7700, 7900, 8100
What I'm looking for is a web site, similar to the one I generously posted, where I can look up ANY code (powertrain, body, ABS, etc) that I may come across.
If anybody has a GM Tech-2, I would assume that would describe the pertinent codes.
Posted on: 2006/10/4 18:12
1996 LT-1
brut RE:Body Codes; ABS Codes
New Albany, IN
1308 Posts
Hey DMG....what does the "E" stand for. In any material I have seen, there is not a code that begins with an "E"
Its generally:
P = Powertrain
B = Body
C = Chassis
U = Undefined
Posted on: 2006/10/4 18:52
2 Posts
That's what I'm trying to find out...emissions? electronics?
Hopefully someone familar with a Tech-2 will chime in.
Posted on: 2006/10/4 21:19
1996 LT-1
