187 user(s) are online (116 user(s) are browsing Forums)
Livin_the_dream Automatic question
robesonia , pa
516 Posts
Put my 88 coupe on the lift and noticed some leaking around the pan on the tranny. Besides the gasket and filter any thing else I should look into? It also seems to be leaking around the output shaft however it could be blow back from the pan?
Posted on: 2008/3/4 2:56
TimAT Re: Automatic question
Gladstone, MO (Kansas City)
38 Posts
2-4 servo on the side just above the pan. Kind of a double step cover about 3" in diameter. They very rarely are any problem. Shifter shaft seal- they do leak- easy fix. And the vent- it's on top of the tranny and will blow juice if the trans gets too hot or builds too much pressure.
Posted on: 2008/3/4 3:47
