197 user(s) are online (94 user(s) are browsing Forums)
captmike13, more...
Also known as SMC.
The only issu...
383tpimachine MOMO steering wheel adapter
Corpus Christi
976 Posts
Have a momo aftermarket steering wheel adapter that I decided not to use.
Never mounted.
Everything in box how you would get it if you ordered it new.
http://www.amazon.com/MOMO-Steering-C ... -Telescopic/dp/B006JGZZU4
Bought $105 shipped.
Selling for $75.
Posted on: 2014/8/15 0:35
1970 El Camino-Awaiting LSX
bogus Re: MOMO steering wheel adapter
20878 Posts
I wish I could do a Momo... but I have airbags...
Posted on: 2014/8/15 19:04
383tpimachine Re: MOMO steering wheel adapter
Corpus Christi
976 Posts
No need for airbags. Easy to remove.
Posted on: 2014/8/16 20:42
20878 Posts
not the problem... you see, for airbags to work, and actually support you, the column is stronger, it doesn't collapse the same way an pre-airbag column collapses.
This means, you get boned by the wheel if the airbag doesn't deploy!!!
Posted on: 2014/8/17 19:34
Corpus Christi
976 Posts
Well damn. No one needs another hole in the face.
Posted on: 2014/8/18 1:09
Corpus Christi
976 Posts
soldddd
Posted on: 2014/8/19 0:11
