220 user(s) are online (185 user(s) are browsing Forums)
jonszr1 which fuel pump is the primary on a zr1
Lone Pine, CA
paul Harvey on my black cr got her running and she just purred got to the front gate and she hit 178 deg and poof she stopped . on a zr1 both pumps run till 178 then the secondary kicks off. so I bought a new pump but don't remember which one of the 2 is the primary .??????
Posted on: 2014/11/18 4:00
bogus Re: which fuel pump is the primary on a zr1
there are also 2 fuel pump relays... on the passenger side, 3rd relay from the trans tunnel... and on the drivers side, 1st relay next to the trans tunnel... Check them both.
If I am reading the manual correctly, the secondary pump will have a light green wire leading to it. The primary has a grey wire. There is also a code for all of this... H54 or H55.
Posted on: 2014/11/18 6:36
-=Jeff=- Re: which fuel pump is the primary on a zr1
Bartlett, IL
573 Posts
my suggestion replace them both.. I think I am on borrowed time on mine..
Need to buy some replacements
Posted on: 2014/11/19 13:30
-=Jeff=-
1990 Corvette ZR-1 #1051
jonszr1 Re: which fuel pump is the primary on a zr1
Lone Pine, CA
trouble is I m cash poor right now lost my job and am trying to pay cash for a place to live . ssi will kick in in april but till then I am selling pencils . the place I am buying is only 32500. but it is on 3/4 of an acre with a 2 car garage go to. homes.com ridgecrest ca 4056 sydnor . set the scan for low to high . it is a little grey place that was listed for 35k . a fixer upper .t least I wount have to pay rent. as ssi will only be 1300 a month
Posted on: 2014/11/19 18:37
Donno if this helps, but... www.rockauto.com has the pumps you need at a fair price.
The Airtex brand, for $39 each, less the 5% discount code (D0499A8E6B7458).
That's a chunk off the street price of $73.00.
You will need strainers, tho. Carter STS1 strainers are $4.11 each.
So... an estimate... with shipping to 93555 (Ridgecrest, CA), and the discount, the final total is $96.43. Which is not much more than the price of one pump and strainer at O'Riely's... Their total is $90.00 ($73 for the pump, $9.99 for the strainer, plus sales tax, 9%(?), that's about $90!)... Damn, that's a killer difference... nearly 2 for 1!!! For the EXACT SAME PART.
Posted on: 2014/11/22 22:43
Lone Pine, CA
wow thanx rock auto is the place to go .
Posted on: 2014/11/22 23:14
