208 user(s) are online (159 user(s) are browsing Forums)
istter1 tko 600 or hydrolic throw out bearing problem?
Bakersfield Ca
2336 Posts
Strange sound. only happened twice but mechanic in shop swears the 1st gear syncro is going out. In heavy stop and go traffic today it happened to me. with foot on clutch pedal rattling happened in 1 gear. Let pedal out and in gear noise gone. any thoughts
Posted on: 2015/2/27 4:46
Carol Burnett
bogus Re: tko 600 or hydrolic throw out bearing problem?
Put it on a lift, and start checking with a stethoscope... see what you hear. That's all I can suggest.
Posted on: 2015/2/27 20:09
CentralCoaster Re: tko 600 or hydrolic throw out bearing problem?
I think your mechanic is broken. The synchro doesn't do anything while in gear with the clutch in.
Posted on: 2015/3/1 1:47
I would call it normal gear rattle.
The basis for your manual trans is a production OEM based gearbox, so it has been very thoroughly tested... What makes your version unique is the case and install.
I wouldn't worry.
Posted on: 2015/3/4 20:55
istter1 Re: tko 600 or hydrolic throw out bearing problem?
Bakersfield Ca
2336 Posts
I agree can't make it act up.
Posted on: 2015/3/8 20:15
Carol Burnett
