125 user(s) are online (33 user(s) are browsing Forums)
tjpreul F/S Split second tuner
I'm going to be removing the Split Second tuning programmer from my car. This is a piggyback system for the 92-93 LT1. This system makes it so you can program with a laptop and not have to remove the prom. You will need a separate wideband to check the AFR. Split Second does not recommend going more than 1.5 times the factory injector size. This is where I have run into issues.
When tuning you have a chart to enter numbers to adjust the fuel and timing. The downside is after changing the parameters you have to shut down the engine to upload the new chart. Which takes about a minute or two. This is still faster than pulling the prom.
I'm asking $300 for the system. If no one is interested I will post it on Ebay when removed.
Here is a link from Split Second.
https://splitsec.com/454-2/
My email:
tjpreul@yahoo.com
Posted on: 2015/5/21 1:52
bogus Re: F/S Split second tuner
20881 Posts
neat concept... but not practical for me here in SoCal... damned CARB... sigh...
Posted on: 2015/5/31 18:47
tjpreul Re: F/S Split second tuner
I've put this on eBay along with both ecm's I had. Priced to sell. http://m.ebay.com/itm/LT1-Engine-Cont ... -/252311067438?nav=SEARCH
Posted on: 2016/3/12 1:48
