155 user(s) are online (96 user(s) are browsing Forums)
Subman I think I found it!
WHITTIER, CA
35 Posts
A few months ago, I kinda hijacked a thread re: a code 32, not passing smog. etc. Mentioning the vacuum solenoid was all but impossible to get, dan0617 send me one he had removed. Thanks, Dan. After I installed it, no change :{
So Dan's is still up for sale.
However, after putting in another booster and M/C this week, I started the car and heard an unusual noise, like an exhaust leak from the right side. A quick look with a flashlight found the challenge - the gasket between the intake manifold and the heat tube from the exhaust had blown out on both sides. It took a while finding the time to fix it and tomorrow we will find out for sure, but, for now, all is well.
Subman
Posted on: 2008/3/16 9:27
jhammons01 Re: I think I found it!
There ya go. inspection can reveal all sorts of things.
I had to break the wifes make up thingy the other day to see something buried.
some guys are way more astute than I am. My muffler guy can hear exhaust leaks as I drive up.....
Posted on: 2008/3/16 17:13
