352 user(s) are online (303 user(s) are browsing Forums)
westy84 Clicking sound at rear of 2002?
Jamestown,N.Y.
9 Posts
I have a clicking sound in the rear my 2002 when i go forward and backwards and also when i let off the gas in first or second gear.I have a 6 speed.I would appreciate any help.thank you.
Posted on: 2016/5/19 21:24
bogus Re: Clicking sound at rear of 2002?
Welcome aboard!
Clicking? IIRC, the drive axles use CV Joints... How many miles?
If I am right, I would check the rubber boots for tears. I will consult my manuals tonight and confirm.
If the boots are torn, then the CVs could be bad... especially if they are clicking.
Posted on: 2016/5/19 21:56
Matatk Re: Clicking sound at rear of 2002?
Welcome to the site!
Any other info you can provide on the car? Mileage, any recent work done, etc?
Have you inspected anything in the rear end or suspension for play/wobble?
A common problem with the C5 (and C6) is the rear axle nut coming loose. You can remove it, clean any rust/etc and relube, then retorque the axle nut to 118 ft lbs.
Good luck.
Posted on: 2016/5/19 21:58
westy84 Re: Clicking sound at rear of 2002?
Jamestown,N.Y.
9 Posts
63k did not notice the clicking when we bought it.No work done to it.I had the local garage look at it,they have never seen a car set up like the newer Corvettes.Dealership prices are so high to have them look at it..We bought it 3 months ago,now out of warranty.
Posted on: 2016/5/20 1:16
Very likely what I posted. Take it apart, clean, lube, and replace the nut. They aren't too expensive. Also check the wheel bearing.
Posted on: 2016/5/20 2:13
The nut is a good starting point! A similar problem exists with the C4... rust sets up in the bearing and causes a clicking sound against the stub axle.
However, the C5 does have CV joints... check the boots.
As for bearings, these are very durable. I would not expect them to be bad.
Posted on: 2016/5/20 17:30
Jamestown,N.Y.
9 Posts
Thank you
Posted on: 2016/5/21 2:11
Any luck over the weekend?
Posted on: 2016/5/24 0:22
Jamestown,N.Y.
9 Posts
Taking car to GM Dealership on Thursday morning.
Posted on: 2016/5/24 13:00
good luck!!!
Posted on: 2016/5/24 15:59
Jamestown,N.Y.
9 Posts
Great News,250$ to drop the axel and Grease the Splines and take a AAA discount.Thank you everybody, pass on the information.
Posted on: 2016/5/26 15:14
So the problem from the C4 migrates to the C5!
Nice to know!!!
Posted on: 2016/5/26 15:58
