132 user(s) are online (85 user(s) are browsing Forums)
istter1 Hard starting after sitting for a while
Bakersfield Ca
2336 Posts
In the morning I have to use the gas pedal to meek it running. For about 30 seconds. Runs rough for a few minutes.
Then smooths out. No vacuumed leaks. Will start checking when I get off work
Posted on: 2016/9/30 12:50
Carol Burnett
bogus Re: Hard starting after sitting for a while
sounds like the IAC needs attention...
Idle Air Controller.
Start there.
Posted on: 2016/10/1 1:04
istter1 Re: Hard starting after sitting for a while
Bakersfield Ca
2336 Posts
Thanks andy
Posted on: 2016/10/1 4:15
Carol Burnett
Matatk Re: Hard starting after sitting for a while
Could also be a leaking injector. Do you have a strong gas smell? Can you perform the fuel pressure leakdown test?
Posted on: 2016/10/1 12:34
Bakersfield Ca
2336 Posts
ThAnks guys it was the IAC.
Posted on: 2016/10/2 18:52
Carol Burnett
