274 user(s) are online (228 user(s) are browsing Forums)
pappyfreebird cooling fan 84 vet
1028 Posts
here we go again...short story..fan ran all times wid key on...tech boys replaced comp.sensor n refilled freon said alls fine...car runs 195 but only 40 here...so out of curiousity i tunrt on air comp.doent run n neither did fan..again cold here but shouldnt fan have tunrt on? second i let idle to 230 degrees n no fan ! jumperd relay n fan runs..new relay (cause had it) no dif..stopped there ..need to ground the sensor by plugs 6-8 ifn fan runs bad sensor right? ok short i said so 1 shouldnt fan run when switched to air con. wearther comp runs er not? 2 ifn fan runs jumperd..most likely is sensor n ifn turns on when ground sensor replace it correct?
Posted on: 2008/3/21 12:06
pappyfreebird Re: cooling fan 84 vet
1028 Posts
ps jus ta add to my bs..i dont see a radiator drain plug.. .could it be broke off...wheres it posed to be located??need a serpinteen belt otso mo bs will be soon nuff
Posted on: 2008/3/21 13:45
1028 Posts
well paps to answer yer 1st question (read yer dayum book foo) temp isnt to come on till 238 (evin though it states 85 it means 84 too)so try n let her heat to 240 n see what happins...oh ok ....so what about air con. isnt fan posed to trun on right when air is ??? or only if compressor runs??? books just sez closed when on..but didnt come on ..but neither did compressor
ps hey mod bruthas please feel free to eliminate this from tech cause it has to much bowcheeyut in it...thanks
thats why i posted in chat
Posted on: 2008/3/21 18:59
Midnight85 Re: cooling fan 84 vet
Streator, IL.
264 Posts
If your a/c isn't charged up the compressor won't kick in so neither will the fans.
"Bowcheeyut??" Pappy, I'm starting to think your way of posting is your way of pulling our leg. Go ahead, I love reading your posts.
Posted on: 2008/3/21 23:46
1028 Posts
i r jus me mid 85...prolly like many ahere a non conformist refugee wahahahaha...jus had ac charged in dec ...but cold here so it ain commin on (hope it dint leak out they tested it) but thanks fer the answer ifn comp dont run neither will fan...so i r prolly awright..but again i play one day n shovel the next ...thats prolly why babble here so much..cant touch it may as well learn n aggravate you cats
Posted on: 2008/3/22 17:15
Streator, IL.
264 Posts
Your a/c will come on no matter what the temperature is outside. If you're turning on the a/c and the compressor doesn't kick in then it has leaked it's charge out. Take it to a pro, find and fix the leak and then you should be set.
Posted on: 2008/3/22 18:23
1028 Posts
now im told that the fan will not run until compessor reaches 300 psi...and compressor will not run ifn air temp is like 30 n 40s...no need fer cold air its cold enuff...my point i keep gettin mixed answers...now my truck 01 s10 comp runs soon as turn to air (clutch fan) but comp runs right away...ive got a 92 lumina fer kid ill try that one to...havent tried the new grandprix..olady aways has it....thnaks fer the answers dudes...im sure ill have mo once i git it on my nephews new lift...woot woot...be cool to look under there n change all the oils
Posted on: 2008/3/24 12:11
