319 user(s) are online (266 user(s) are browsing Forums)
GRIS, more...
90Vert Lowering Back End Question
Georgetown On.
29 Posts
Hi Guys I wonder if anyone has a solution to my problem.
Yesterday I lowered the tail end of my 90 Vert. The car always sat a bit lower on the drivers side, after lowering it I still have the same problem it sits 3/8" lower on the Driver side.
How do I correct this problem?
Thanks for any help.
Posted on: 2008/3/22 23:04
CasetheCorvetteman Re: Lowering Back End Question
Yep, thats pretty normal for a car that mainly only has a driver and no passenger, what you can do is pull the rear spring out and turn it around, that will make it better.
Posted on: 2008/3/23 0:15
