246 user(s) are online (214 user(s) are browsing Forums)
pappyfreebird heres nuther brain fug
1028 Posts
seems i has me too much air in right front n too lil in left..seems keep beyun issue,,long short seems some idjut switched wheels n never recalulated tpms..thus the issue was fillin one too full think low etc..so read a few tips on mabee since 05 i might has me early 05 n will werk with magnet..n nuther said might werk like yukon n let air out horn honks etc..simply switched front wheels after fuggin roun hr with relearn chit,,wala done ..but real issue was in tryun find relearn tire,,cant find it leading to nuther issue as hit acc in car fuggers sez service steering lock ..did this once before n had to unhook neg to make run again..so my rig must have the steerin lock bs that c5 had..if you push acc er start wid no clutch (same as acc) itll throw service column lock n car no start until pull neg fer second..easy donbt use acc..but why does she do this??? and is ther anyway program tpms wid buyin fuggin toy to do it
Posted on: 2018/6/1 15:38
pappyfreebird Re: heres nuther brain fug
1028 Posts
mo think i wonder how low batt got as i dinked tryun make it show me relearn message (that i rekon it doesnt show in o5 n up)..naw if i hit acc she will do steering lock bs,,never issue jus start n go
Posted on: 2018/6/1 17:41
teebee Re: heres nuther brain fug
12364 Posts
That’s a battery issue, pappy. Needs to have 12.5 volts and a good reserve capacity. Check the battery.
Posted on: 2018/6/2 17:50
1028 Posts
yea im real curious now teebee..drove her to werk n noticed window nawt closing , neither one closes ..so searched n found window indexing (must happind after unhookin batt to git running other day) so i go out jus now n fug me i cant reindex unless i hit the acc the dreaded acc or start no clutch cuases same..bingo got windows werkin n now have the fargun steering lock no start again..so unhooked batt thinkin fun game this is gonna be,,but in rehookin windows still werk n car starts fine..so i dont think its column lock , cause never n issue unless touch acc er start no clutch same thing i think ,, 46k on her now n 13 yrs old i woulda thunk hoped had a bypass by now,,dunno..ony gives me chit ifn i pushh acc..starts runs everytime ..so i dont touch acc n fine..but tried program tires n bingo it rose its ugly head at me again..i need to know now i cant have half assed chit i dont know bout you know wud i mean
ps think i did reindex with car running too so fer next guy maybe try that before the stupid acc chit thing happins..
any clues bruthas all be preciated,,again nio issues unless use acc..ain had that long but fires everytime unless touch acc..n wheel does lock n unlock when this happins so eems to be werkin (which i geuss tells me no bypass in her too)
Posted on: 2018/6/4 17:34
1028 Posts
as fer this one well wid no column lock acc issues i dont hafta unhook batt so doesnt fug wid the windows but now ifn do i kin use my acc mode to simply (strange werd but index my windows) wala easy ..yea lecrics great when werk suck big tittites when dont period
Posted on: 2018/6/16 18:01
