254 user(s) are online (199 user(s) are browsing Forums)
bronze84 Parking Brake Lamp Switch
Murfreesboro, TN
1 Posts
I just finished cleaning and greasing my parking brake handle assembly on my '84. It was locked up from years of no use. The switch for the dash lamp is mounted to the rear of the handle bracket. It is a simple spring-type switch. When I apply light pressure to the switch, the lamp lights. Release it, it goes off. I can't figure out what is supposed to act on the switch to depress it and close the circuit. It doesn't look like the handle would do it, since the handle lies horizontal after applying the brake. What is supposed to press the switch and hold it closed when the parking brake is on? Anyone have a diagram? I have a photo which I could email but couldn't get it to upload here. Thanks.
Posted on: 2008/3/29 22:59
