162 user(s) are online (136 user(s) are browsing Forums)
'W' Series:
5.7L 348ci - 1958 thru 1964
6.7L 409ci - 1961 thru 1965
7.0L 427ci (Z11...
EcoVette trip-o-meter reset
Planet Earth
31 Posts
Hey everyone,
I've got a 94 and I'm having a little trouble resetting my tripometer. No problem resetting the fuel monitor, but with out resetting the trip, the average mpg isn't accurate for the current trip.
anyone know the sequence for button pushing? I get it once and a while, but dont know what I did.
Thanks....
Posted on: 2008/4/3 19:45
Its like DajaVu all over again
bogus Re: trip-o-meter reset
select the trip-o-meter, then hit the reset trip button.
Resetting the trip isn't required to effect change to the fuel. The way the system works is based soley relating speed back to RPMs and fuel usage.
Posted on: 2008/4/3 19:53
CasetheCorvetteman Re: trip-o-meter reset
There is no sequence. Hold the trip reset button. Its that simple.
It makes no difference what so ever to the displayed MPG though.
Posted on: 2008/4/3 20:00
EcoVette Re: trip-o-meter reset
Planet Earth
31 Posts
O.K.
so I just started my car, selected fuel, hit reset and as requested it reset. however, when I selected trip and it displayed trip milage, then hit reset....nothing changed.
what gives. It appears both buttons work (make contact) all 3 buttons if you include fuel. Here I thought I was tripp'n.
any ideas??
Posted on: 2008/4/3 20:02
Dads90 Re: trip-o-meter reset
Pearland, Tx
318 Posts
I could only suggest the trip reset side is bad. That whole side with the buttons is an easy replacement.
Posted on: 2008/4/4 3:31
Hold the button longer. Just pressing it doesnt reset the trip meter.
Dads90, your avitar is huge mate.
Posted on: 2008/4/4 5:56
agreed on both counts, casey.
Posted on: 2008/4/4 14:37
No worries mate ;)
Posted on: 2008/4/5 11:45
