196 user(s) are online (158 user(s) are browsing Forums)
BIGREDWING Broken Cup Holder Cover
Between Two Rivers in Southern Maryland
12 Posts
A quick Search didn't turn up anything and I have not disassembled the center console yet so here goes...
The rear hinge point of the cup holder door on the console has broken and now the door doesn't work or set quite right. The door itself is fine. In anybody elses experience with this vital component can that part of the console be replaced or am I looking at replacing the entire cover? I think I'd engineer a fix first but maybe somebody has an idea. Thanks!
Posted on: 2008/4/4 16:35
pianoguy Re: Broken Cup Holder Cover
If it's just a plastic tab or something under there, you might be able to fix it with Plastex:
http://plastex.home.att.net/
Posted on: 2008/4/4 17:26
BIGREDWING Re: Broken Cup Holder Cover
12 Posts
Wow, I might have to try that out! Thanks. That stuff could be a "magic bullet" for a number of problems I have.
Posted on: 2008/4/4 19:08
