271 user(s) are online (224 user(s) are browsing Forums)
vetasaurus 87 c4 roller cam or not?
2 Posts
hey guys need some help just bought a 87 convertible in australia and am going to do a engine rebuild in winter and need to know if all 87 mod had a roller cam i looked into the rocker covers and couldn't see any rollers on the end of the rockers it would need them if it was a roller cam i thought.any help would be helpfull
Posted on: 2006/2/21 6:47
VR-92 RE:87 c4 roller cam or not?
68 Posts
Pretty sure all L98s have roller cams.
Posted on: 2006/2/21 20:08
Skidmarks RE:87 c4 roller cam or not?
Blue Mound, Illinois
98 Posts
The roller cam was introduced in '87 I believe. They way you described looking at your rockers, I believe you are confusing a cam with roller lifters vs roller rocker arms. Your car has a roller cam (roller lifters), but does not have roller rocker arms, although roller rockers can be installed as an upgrade over stock.
Just as a side note: it's also possible to build and engine with roller rocker arms without having a roller cam.
I hope that cleared things up.
Posted on: 2006/2/24 17:15
bogus RE:87 c4 roller cam or not?
1987 is a roller lifter.
the roller lifter started with the aluminum heads in 1986.
Posted on: 2006/3/1 5:50
