185 user(s) are online (124 user(s) are browsing Forums)
skirlin Window Indexing and doors won't open?
Caledonia Michigan
277 Posts
I had been reading that the door windows index down for the door to open and close when the door closes, is this true? It was also noted that the doors won't open if they don't go down, thus the passenger can not enter/exit the vehicle if this process doesn't happen? Also, there is a manual release for the doors? Isn't that the door handle? I haven't been in the newer one yet so I do not know. Maybe this is an issue with the new vette and not the C6?
This thread is simply my interest in a solution to an engineering challenge, and I used this section because there is not currently a C7 forum to inquire. Thanks.
Posted on: 2008/4/12 1:54
Edited by skirlin on 2008/4/12 3:45:13
Edited by skirlin on 2008/4/12 3:46:00
RUBY9246 Re: Window Indexing and doors won't open?
North Jersey
80 Posts
[quote]
Yes
There is no Door handle. Is a touch button on the door.
The emergency realease is a lever on the floor.
Posted on: 2008/4/12 14:11
skirlin Re: Window Indexing and doors won't open?
Caledonia Michigan
277 Posts
Thanks, now THAT is interesting. The guys I hang out with like the 'did you know..' game and thats never been brought up.
Posted on: 2008/4/14 1:34
