polish41 | Turn signal | ||
The turn signal lamp inside the car works intermitantly. I suppose I will have to tear out the dash to replace it or clean the base so it will make better contact. And I know it's supposed to be intermitant when the its working. Sometimes it will work when the turn signal is on and sometimes it doesn't.
Posted on: 2008/4/17 0:24
If your not living life on the edge your taking up to much space. |
bogus | Re: Turn signal | ||
that sounds like a loose connection...
Posted on: 2008/4/17 1:37
polish41 | Re: Turn signal | ||
I tried tapping on the dash but nothing happened. Also tried wiggling the stalk with no results.
Posted on: 2008/4/17 1:41
the stalk is so disconnected from the process, it isn't even funny.
I suspect it's a trip into the IP... sorry to say. |
Posted on: 2008/4/17 2:19
I guess I'll look into the Batee web site and see what I can find.
Posted on: 2008/4/17 19:53
