315 user(s) are online (247 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Collector Edition
RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
red_johnny The carb is pulled...
Just pulled it out, pretty easy actually, 3 bolts plus removing the gas tank which is two bolts. Anywho, this is it. I dunno if you can see the build up inside the carb or not. Its definately time to either replace it or rebuilt it.
Posted on: 2006/12/10 19:34
freakd RE:The carb is pulled...
727 Posts
replace it :thumbright:
Posted on: 2006/12/10 19:43
bogus RE:The carb is pulled...
clean it, put in a new needle and spring.
These things are way overpriced for what they do... and they get water in them all the time.
To be honest, this is old school tech! I mean, these carbs are gravity fed and are just 1930s tech in nice aluminum.
Clean it well, replace the needle and life will be grand.
The only reason to install a new carb is to get a performance unit.
Posted on: 2006/12/10 20:21
red_johnny RE:The carb is pulled...
Okie Dookie I will look into fixing it
Posted on: 2006/12/10 22:11
keep me posted!
you need to convert that over to alcohol.
Posted on: 2006/12/11 1:39
How does one convert over to alcohol? I am not going to, at least not right now but sounds like that where all the powers at for these small little buggers.
Posted on: 2006/12/11 2:34
with these things, it requires a lot more engine guts (meaning, you can't convert a basic motor) than you have!
The alcohol comes in once the compression climes and heat becomes a real problem...
there is a kart track near Dover, DE... a few years back (when I still lived there), my friend Travis and I went to watch a co-workers son race.
the boy was racing in a controlled class...
but you shoulda heared them open class motors!!! 5hp briggs blocks, bored, stroked, sleaved, roller bearings, cam, all sorts of alloys..damned things put out 45hp or so!!! with a 14000 rpm redline! they sounded like single cylinder top fuelers!
Posted on: 2006/12/11 4:51
Ok, just wondering. I stilll find it amazing, 45 HP off a 5 HP block. I am looking at a few upgrades but the biggest 3 things I want to do right now is:
1. Get it running
2. New front tires
3. Put some lights on it (I am looking into it, I may need a alturnator and a battery) If I do this I may install a starter too.
I just dont want to dump too much into it since its, from what I have been reading, a cheaply welded frame. I would upgrade the frame to have suspension but I would have to re-enforce EVERY joint! I guess its one step at a time and I will see what happens. Maybe down the road I will get me a nice one with suspension.
Posted on: 2006/12/11 14:07
RPMs are the trick.... lotsa RPMs.
It really isn't that crazy. Think about it... Honda motorbikes with 150cc or so are putting out 30hp...
Posted on: 2006/12/12 5:13
Ok, I found out that my engine is NOT starter capable. I also found out they dont make alturnators for these sizes they make stators. Its basically a small alturnator. A stator kit requires a flywheel with magnetic pick ups, the stator, and a regulator and WHALA, I have power.
Posted on: 2006/12/12 12:44
Just ordered the rebuild kit for the carb :thumbleft:
Carb rebuild kit
Posted on: 2006/12/12 13:15
I have been around with those systems on lawn tractors.
Do a bit of digging, push mowers have starters... I donno about alternators, tho... You can always put a car battery in the thing and use a charger to trickle it back up.
Posted on: 2006/12/13 5:04
Carb rebuild kit
I thought it looked a little funny... it's a Tecumseh....
Posted on: 2006/12/13 5:05
This engine I would have to drill and tap holes for the starter to mount to and also I think there is some modding that would have to be done to the shaft. It would be cheaper just to buy a starter capable engine.
Posted on: 2006/12/13 11:25
The kit finally shipped!! I should have it ready by christmas
Posted on: 2006/12/14 19:24
Just finished the rebuild which took me like 30 mins, and it was pretty easy. Now I have to wait until tomorrow to put it on and I hope that fixes everything.
Posted on: 2006/12/17 0:54
