266 user(s) are online (219 user(s) are browsing Forums)
c4-zo7-91 injector size question ??
312 Posts
hi guys,
just wandering your thoughts/ideas on wheather 30 lb ford motor sport red top fuel injectors will be larger enough with a aeromotive adjustable fuel regulator and a engine of 388 c.i that will put out roughly 450-500 rear wheel horsepower ???
are ford motor sport injectors of good quality/design ??
who are they made bye also ??
if not they may be larger enough i may have to get some larger injectors 36/42 lb ??
also what is better pintle or disk type injectors ??
i heard that if your injectors are to large that it can hurt performance and spray pattern/fuel atomization ??
thanks guys
cheers
glen
Posted on: 2008/4/26 8:20
Edited by c4-zo7-91 on 2008/4/26 21:30:49
CasetheCorvetteman Re: injector size question ??
Glen, i am using them, although mine are the Cobalt tops, which are 36lb/hr. Great injectors. Thats what id recomend to you, they flow 38lb/hr with the stock 43.5psi fuel reg, and i think i paid about $380 or so shipped to my door from MAXX WRENCH.
They are made by Bosch
Posted on: 2008/4/26 10:21
c4-zo7-91 Re: injector size question ??
312 Posts
hi case,
how are ya!
thanks for the reply mate!
so would my 30 lb flow at 32 lb then @ 43.5 psi fuel preasure fuel reg then ??
cheers
glen
Posted on: 2008/4/26 21:29
Im good thanks mate, how are you?
Well not quite, the Bosch 30s would flow about 31.7lbs/hr @ 43.5psi
Posted on: 2008/4/26 21:42
