130 user(s) are online (98 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Grand Sport
RPO Z16.
A one year special. 1000 were made to honor both the end of the C4 and the original racers, called Grand Sports, from 1963.
All were...
lmchugh1 Steering Rack problem?
Numidia, PA
3 Posts
I know my rack is bad becasue when it's cold out, the steering sticks (for lack of a better term). I'll turn the wheel and all of a sudden it feels like I don't have power steering, but only for a second.
What I'm confused about is that when the steering sticks, the steering wheel with move about 2 inches...It makes a clicking noise when this happens. I get the impression that something is stripped on the column, has anyone ever heard of this?
Also, if I turn the key to the "on" position to unlock the column, and then turn the wheel with the car not running, the wheel will rotate about two inches before it stops....before the tires even move. This stripping action occurs easily..
Does anyone have any idea what this could be?..Thanks.
Posted on: 2006/12/23 5:17
freakd RE:Steering Rack problem?
727 Posts
i know the steering rack is bad, as mine does the same, as for the clicking, i'm not sure, but it sure sounds like somethings amiss, i would get it checked out before you do any serious driving
Posted on: 2006/12/25 0:01
lmchugh1 RE:Steering Rack problem?
Numidia, PA
3 Posts
Thanks, I'll get it check out.....
Posted on: 2006/12/26 5:14
bogus RE:Steering Rack problem?
what year is your Vette?
This sounds odd to me. There isn't any connection inside the column that would cause this.
I would check the ujoints under the hood, tho.
I wonder if the security pin/lock plate are binding up?
Posted on: 2006/12/26 18:16
lmchugh1 vette steering
Numidia, PA
3 Posts
My Vette's an 84...the clicking and stripping seems to be coming from inside..but I'm not sure...I'll check out the security pin/lock plate..Thanks..
Posted on: 2006/12/28 22:59
there could be something binding down by the tilt mechanism, tho...
it might require taking it apart and seeing what it broke.
Posted on: 2006/12/31 22:08
bosshogg RE:Steering Rack problem?
N.E. Indiana
1 Posts
Mine does the same thing cold...let me know what you find out...I know...More money
JOHN
Posted on: 2007/1/22 18:29
