josephf31 | Fuel gauge always reads empty | ||
On my 1991 L98 auto coupe -- any suggestions, hints, etc?
Thanks all! |
Posted on: 2008/5/15 18:22
josephf31 | Re: Fuel gauge always reads empty | ||
Has noone here ever had this problem? I see posts and tech FAQs about the fuel guage always reading full, but not empty...anyone? Thanks!
Posted on: 2008/5/19 1:45
2002 Magnetic Red C5 6 spd LS1 convertible |
NC Kid | Re: Fuel gauge always reads empty | ||
Maybe your sending unit is shot. Dash have any issues?
Posted on: 2008/5/19 2:00
bogus | Re: Fuel gauge always reads empty | ||
empty makes me think sender. They do have a history of being junk.
Full, IIRC, means that the circuit is open... empty means closed. So, I would check the float and the resistor. IF the resistor looks burned, you can disassemble and flip it over to use the other side. I read that on another forum a few years back. |
Posted on: 2008/5/19 2:57
That would be great if I can "rebuild" the existing one, I understand they are pretty expensive. Are they easy to remove?
Posted on: 2008/5/19 23:34
I was going to suggest the FAQ tech tip but you said yours reads empty...Goodluck.
Posted on: 2008/5/20 0:19
