121 user(s) are online (47 user(s) are browsing Forums)
1963 through 1967 Corvette.
JonnyAngle Heater core residual problems?
Minneapolis, MN
151 Posts
In my 86, the heater core is shot. Would that cause the climate control lights to flicker? The rest of the dash works perfectly.
EDIT: Just took another look and it appears that there are two "pipes" that have red hoses that go through the firewall. Can I just connect those 2 hoses to bypass the heater core? I've never even turned the temperature control on, I always use the 4-65 Air Conditioner. I suppose it would be 2-65 in the Vette. Any reason I wouldn't want to bypass the heater core?
Posted on: 2008/5/27 4:16
bogus Re: Heater core residual problems?
yes, you can bypass the heater core that way.
the controller freaks out on it's own... Dr Dons fixes them - www.doctordons.com, IIRC. they charge about $60.00 to reman them.
Posted on: 2008/5/27 5:49
